Balthazar B
- Joined
- Nov 1, 2022
- Messages
- 335
Ran into an odd Airplay issue. I've reported it to WiiM, and now sharing it here for thoughts/suggestions:
Cheers!
- Have two WiiM Pros, and starting out one (Dee) was on WiFi, the other (Dum) on Ethernet.
- From the Music application on a Macbook, could see both WiiMs as Airplay devices. The Mac and WiiMs are on the same network/VLAN, and all on current OS/firmware releases.
- I could direct music to Dee successfully, but got a connection failure warning when trying to select Dum (cannot connect to Dum, unable to play audio).
- So hypothesizing that Dum's Ethernet connection could be the issue, I turned on WiFi on Dum, disconnected Ethernet, and rebooted.
- Dee, Dum, and Mac now all on the same network/SSID.
- In the WiiM Home app, I did need to re-establish the connection to Dum, but its settings were as before. On both WiiMs, IP6 is set to On.
- But now from the Mac, while I can continue to see Dee in the Music app, Dum is nowhere to be found. Rebooting the WiiM, Mac, etc., doesn't fix the issue. I can see all the devices connected to my WiFi in the router's control screen.
- Unfortunately, I don't have another Apple device on hand to see if the issue can be isolated to the Mac.
Cheers!
