Audio Output selector
mikel
Dec 13, 2023
17
Poland
Since my Wiim Pro Plus switches input sources perfectly alone it would be extremly handy if you could opt if source switch on remote is switching "source" or "output". Right now I have Wiim Pro plus serving my Integrated amplifier on Line out and DAC/headphone amplifier via Coaxial out. My dream would be to be able to limit number of Audio Out options to only those that I need and switch them via remote. Right now to switch between Indegrated and DAC/Head Amp I have to dig deep in menu every time. Other than that... this is my best audio purchase of all time! Thank you!
Upvote 0
Yes yes yes!
But we should also be able to limit the input sources to only those we use as well. I’ve had issues with the auto-switching with HDMI so have that turned off and it would be much more user friendly to just have useful inputs selectable. As OP originally requested, the same goes for outputs. While I’m rambling about related features, unique audio settings per output would also be useful (EQ, volume limits, fixed volume, subwoofer use, etc)
You could use a smart preset to select an output and other options. Go to the preset page, choose an empty preset and set the options you want there.
Oh my God youre right! Thank you! Presets works like a charm! Is this not the beste device ever!? Its build in DAC is great to. Fantastic. My Wiim is powerd by linear power supply! Highly recommend! I added another DAC just because i want something to experiment with and have headphone amp seperatly!
You can also change the output from the 'Now Playing' screen (click on the current output it shows), so not deep in the menus.
