Chromecast for Mini?
dbruceday
Mar 13, 2023
5
Does anyone know if there are any plans to update the Mini to support Chromecast? WiiM supports Airplay and Chromecast in the Pro. Currently Airplay is supported in the Mini but not Chromecast.
Check the latest Mini firmware update and Chromecast is mentioned see below on point 3 in bug fixes. Is it now supported?
4.6.603557 (Latest)​
Release date:
1 / 4 / 2024
What's New:
  1. Enhanced Volume Balance (Compatible with the Latest App): We've introduced a Volume Balance feature, allowing you to fine-tune the audio levels between the left and right channels for a more personalized listening experience.
Bug Fixes:
  1. Update Behavior Correction: Corrected an issue where updates would inadvertently initiate during playback from Aux-in input. Updates will now occur at more appropriate times to avoid disruption.
  2. Qobuz Playback Improvement: Implemented a feature to automatically skip to the next track if the current one is unavailable, maintaining a seamless listening flow.
  3. Chromecast Playback Issue: Fixed a bug that resulted in no sound when using Chromecast. Users can now seamlessly transition to Chromecast without audio interruptions.
Release date:
1 / 4 / 2024
What's New:
Bug Fixes:
Reckon it's just a mistake - the mini simply doesn't have the necessary hardware for chromecast.
No, upgrade to pro then it’s ready for you to use it.
