Help with External DAC
21jim
Mar 16, 2023
I have a wiim mini streamer that I am connecting via spdif from wiim to Modi3+ External dac
From there I’m using rca out of Modi to integrated amp rca
I’m not getting any sound when I do this? I have the setting I believe correct on the wiim mini app (audio output spdif) and the toggle switch on the modi set to middle (optical toslink )- no sound ?
Would you have any idea what I might be doing wrong ?
Thank you
Sent from my iPhone
Make sure your toslink plug sits tightly in the streamer, it tends to fall out. Also you may check with headphones if mini is actually playing anything.
Thank you - it was my bad , didn’t remove tips from cable - ugh - working now
I did that the other day too.
15 secs wondering why the darn toslink wouldn't click into place, and then it clicked (get it?)!
