Introducing the WiiM Edition of the Audio Pro A10 MKII and C10 MKII
RyanWithWiiM
WiiM Admin
Staff member
Sep 23, 2024
567
We're excited to announce that we're bringing the WiiM OS with all its functionality and features to Audio Pro speakers with the A10 MKII WiiM Edition and C10 MKII WiiM Edition. Experience the power of the WiiM OS driving these speakers to new heights starting Oct 2024.
AD_4nXcwCjwEuMlvV8MUo14WyKG5jkwcUSNeC2sgXik2TBKo0GrkVI7aDw2apAObrk-gdq5OqV8lkMJOHtVj0EkKOvKBThjBCPI4IJ7VH2udlf4-6_3xx2WKWq1jWyVFXAYMkz-ImOU6TZ0HfARXtLrVa4NjthBX
AD_4nXcDLKd5Vb4rpRv11K-PrWvTHxNalUjwOgMurLrZCAITjUig3aLoxNQXx7nqnyphIE2K225k9ll8504vSyj57y-xePstoRnPDdao28CRTiAlxlud7HxfMNZwjITaCL4GOZ37uf87x266AyDH0XiyjotU09Aw
The A10 MKII is perfect for small spaces, with its compact design and 50-watt output, while the C10 MKII is ideal for larger rooms, featuring an 80-watt sound system with a 5.25" woofer and two textile dome tweeters. Both speakers deliver exceptional sound quality, and we've now optimized these speakers for WiiM OS, they're now smarter than ever!
Bringing the Power of WiiM Home OS to Audio Pro
Our innovative WiiM Home OS is at the heart of the WiiM products you know already, and these new smart speakers are powered by those same smarts, providing a seamless and intuitive user experience. With the WiiM Home App, you can effortlessly manage your music, podcasts, audiobooks, and internet radio from one central place. Manage all your music and devices from one place, making it easy to switch between your favorite music services like Spotify, Amazon Music, TIDAL, Deezer, Qobuz, and your personal music library. Plus, you can control all your WiiM-compatible devices with just a few taps.
Seamless Casting, Every Time
We've made sure that WiiM OS on the Audio Pro A10 MKII and C10 MKII plays nicely with all your favorite casting services, including Apple AirPlay, Google Chromecast, DLNA, Spotify Connect, and TIDAL Connect. That means you can stream your music from any device, without any hassle, and enjoy the highest sound quality.
Immersive Listening, No Interruptions
Our gapless playback feature supports up to 24-bit/192 kHz audio quality, so you can enjoy your music without any interruptions. Whether you're streaming a full album or a curated playlist, the music just keeps flowing.
Connect Your Way
WiiM OS is all about flexibility. You can connect your turntable, TV, or stereo system, and enjoy your music the way you want to. We've also included built-in support for voice assistants like Google Assistant, and Siri, so you can control your music hands-free.
Sound Shaped by You (and Your Room!)
We know that every room is different, which is why we've developed our patent-pending automatic room correction feature. This clever tech adjusts the sound to fit your space, so you get the best possible listening experience. Plus, you can fine-tune the sound to your liking with our extensive EQ customization options. And, with our advanced bass management feature, you can get the perfect balance of bass and treble.
Always Up-to-Date
We're committed to keeping your WiiM OS up-to-date with the latest features and improvements. That means you'll get regular firmware updates, new features, and expanded compatibility with the latest music services. Your music experience will always be fresh and exciting!
What You Can Expect
The A10 MKII WiiM Edition and C10 MKII WiiM Edition speakers are designed to provide a seamless listening experience. They’ll integrate with existing WiiM devices and be controlled with the same app, allowing for synchronous playback. With the WiiM Edition of these speakers you can:
  • Stream music from your favorite services, like Spotify, Amazon Music, Deezer, Qobuz, TIDAL, and many more including your own music library.
  • Control your speakers with your voice using Google Assistant, and Siri
  • Customize your sound with our intuitive EQ settings
  • Enjoy high-quality audio with gapless playback and streaming up to 24-bit/192 kHz
Continuous Innovation
At WiiM, we're committed to continuously refining your audio experience. Our regular firmware updates ensure that you'll always have access to the latest features, music services, and enhanced audio quality.
Experience the Future of Smart Speaker Technology Today
Discover the perfect blend of innovative technology and exceptional sound quality with the AudioPro A10 MKII WiiM Edition and C10 MKII WiiM Edition. Upgrade your home entertainment experience with WiiM Home OS and enjoy unparalleled music control and customization.
C10 MKII WiiM Edition and A10 MKII WiiM Edition Specifications Comparison Chart
FeatureA10 MKII WiiM EditionC10 MKII WiiM Edition
TypePowered speaker with dual low frequency radiatorsPowered stereo speaker with bass reflex
ColorsDark GrayBlack
AmplifierDigital Class D, 52 WDigital Class D, 2x20W + 40W
Tweeter1 x 1.25" BMR2 x ¾” textile dome tweeter
Woofer1 x 3" long throw1 x 5.25”
Low frequency radiators2 x 4.5"-
Frequency Range55–20.000 Hz45–22.000Hz
Crossover300 Hz2.500Hz
Audio InputWiFi, Bluetooth 5.0, 3.5 mmWiFi, Bluetooth 5.0, RCA
Audio Output Connections-Sub output
EQ OptionsIndependent EQ settings, 24 preset EQ settings, 10-band graphic and parametric EQ, Automatic room correctionIndependent EQ settings, 24 preset EQ settings, 10-band graphic and parametric EQ, Automatic room correction
Streaming SupportAirPlay, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready (Coming Soon)AirPlay, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready (Coming Soon)
Multi-roomWiiM, AirPlay, Chromecast AudioWiiM, AirPlay, Chromecast Audio
Stereo PairingYesYes
Connectivity & Power100-240V AC input, Wi-Fi 5, Bluetooth 5.0100-240V AC input, Wi-Fi 5, Bluetooth 5.0
Dimensions193 x 140 x 140 mm166 x 320 x 180 mm
Weight3.3 lbs (1.5 kg)8.6 lbs (3.9 kg)
Physical ButtonsPower/standby, Source switch, 4 preset buttons, Play/Pause, volume, reset, Bluetooth pairingPower/standby, Source switch, 6 preset buttons, Play/Pause, volume, reset, Bluetooth pairing
LED Indicators3 white LEDs for status, 10 white LEDs for volume indication3 white LEDs for status
Power Consumption1.8 W-0.3 W-3 W1.7 W/<0.5 W/6.2 W
Wall Bracket Insert NutM6-
Price & Availability$229, Oct 2024$399, Oct 2024
Find them on Amazon Audio Pro A10 MKII WiiM Edition and Audio Pro C10 MKII WiiM Edition.
Where will these sit vis-a-vis the streaming models e.g. will they support tings like Squeezelite, be Roon Ready like the Pro onwards, or are they commensurate with the WiiM Mini?
Edit: ignore, just re-read the specs and saw Roon Ready and LMS, so I guess these will both play further up the scale than the Mini. As they support Squeezelite, the LMS crowd might be very pleased too :)
We're excited to announce that we're is bringing the WiiM OS with all its functionality and features to Audio Pro speakers with the A10 MKII WiiM Edition and C10 MKII WiiM Edition. Experience the power of the WiiM OS driving these speakers to new heights starting Oct 2024.
The A10 MKII is perfect for small spaces, with its compact design and 50-watt output, while the C10 MKII is ideal for larger rooms, featuring an 80-watt sound system with a 5.25" woofer and two textile dome tweeters. Both speakers deliver exceptional sound quality, and with the integration of WiiM OS, they're now smarter than ever!
Connect Your Way
WiiM OS is all about flexibility. You can connect your turntable, TV, or stereo system, and enjoy your music the way you want to. We've also included built-in support for voice assistants like Google Assistant, Amazon Alexa, and Siri, so you can control your music hands-free.
Always Up-to-Date
What You Can Expect
  • Control your speakers with your voice using Google Assistant, Siri, and Alexa
Streaming SupportAirPlay, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon ReadyAirPlay, Chromecast Audio, Spotify Connect, TIDAL Connect, DLNA, LMS, Roon Ready
Is the A10 crossover 300hz correct?
This is a very exciting new product!
Hey are there hardware differences with the WiiM editions? I just purchased three A10 MKIIs a couple months ago. They work great with the WiiM Pro+, but I am wondering if a firmware update will enable all the additional WiiM features?
Did cross my mind too but perhaps Audio Pro’s support team are better served to answer that.
I'll double check that I have the right info there, I'll let you know if a typo slipped in.
There are some hardware differences separating the normal A10 MKIIs from the WiiM Editions. The WiiM Editions are built for the WiiM OS, while they're also going to work with Audio Pro’s multiroom system, the WiiM Edition offers more advanced multiroom features and will continue to evolve with regular software updates.
Alexa and Alexa Cast don’t warrant a mention on the Amazon listings while the opening post mentions “Control your speakers with your voice using Google Assistant, Siri, and Alexa”, there’s scant mention of them anywhere else, with Alexa MRM not listed under multi-room in the table. Is this deliberate?
wow this is great news, they both seem awesome.. quick question both are 100% wired speakers right? no rechargable battery for outdoor use right? any idea when it would be available for Amazon US?
Watch out expensive streamer and speakers here comes wiim offering broad range of products that’s affordable and upgradeable of features through firmware update at no additional cost.
Any further details on the the hardware differences? I guess maybe the WiiM firmware could require more memory, but it seems unlikely. For the record, the pre-existing A10 MKII is recognized by the WiiM Home app just like another WiiM device (for that matter the WiiM Pro+ is likewise seamless with the Audio Pro app as well).
I will inquire further with Audio Pro...
For any who are curious, I have found the A10 MKIIs to have great sound for their size. Overall the highs are maybe a bit rolled off, decent bass for their size, good wide dispersion. A little insensitive, but volume levels are very adequate for their intended usage. Coming from the Sonos One speakers that they replaced, I think the A10s are superior.
