Hulle Sack
Senior Member
- Joined
- Dec 17, 2022
- Messages
- 44
Have the Pro extensively tested, it's connected via Ethernet and hangs together with my HTPC on an unmanaged switch. Via coax to the SMSL SU-6 DAC and further to the Yamaha AX-497. Two pairs of speakers connected, mainly I use my Heco Metas- but also, depending on the music style, my Infinity Alpha-speaker.
Tidal Connect works flawlessly (as previously also with my two WiiM Minis), the WiiM app will be better and beter, great. With PowerAmp I can wonderfully stream local tracks via Chromecast (gapless), DLNA with Bubble UPnP, Hifi-Cast, Neutron from the NAS (MinimServer) to the PRO - everything works perfectly with small exception: The PRO is ready for streaming after switching on as a DLNA- and Cromecast- device, but after a while no longer as a DLNA client in the network available (the apps don't find the PRO as a DLNA-device), only after it was once de-energized, it emerges as a DLNA client again. As a Chromecast device, however, the PRO is always available (UPDATE 2023/03/04: This issue was solved by using another network-switch). Due to the fact, that I can use also the WiiM-app instead of Bubble etc., I am very satisfied so far, an excellent device. Also, I think it will be fixed in the future.
