jeromeof
Will there be more advanced DSP EQ on the Pro. For example a set of PEQ filters would be amazing?
PEQ will be provided shortly for both WiiM Mini and Pro. Please stay tuned and welcome your comments/improvement ideas.Will there be more advanced DSP EQ on the Pro. For example a set of PEQ filters would be amazing?
After some hard work, we believe PEQ (especially 3 bands one) works well for both Mini and Pro. Pro can support more bands PEQ due to more powerful CPU. We'll release it when passes our internal tests. Please stay tuned!if there really should be a peq with the mini .. (or the pro)
there will be something really interesting to dig into....
will become possible to manage on a mini, small etc., filtering and communication with a subwoofer via the analog output in parallel with the main speakers on the toslink...or alone...
(like the small dayton lf dsp )
see a real triphonic management etc...
etc
(the dsp, even modest, dedicated to the processing of subwoofers is very effective)
ps.. this peq you had announced for months before declaring that not possible finally on a mini, not powerful enough and memory, will be possible only on the pro... so your new announcement seems very surprising...
do you hire new resources to work, develop, settle problems, on the "audio" aspect?
If you could make it 5 bands for Mini that would be better !After some hard work, we believe PEQ (especially 3 bands one) works well for both Mini and Pro. Pro can support more bands PEQ due to more powerful CPU. We'll release it when passes our internal tests. Please stay tuned!
I'll bring this request back to our eng. team for consideration. Thank you!If you could make it 5 bands for Mini that would be better !
Ten bands on every input plus 10 bands on every output, effectively 20 bands per channel in stereo mode. Hard to be beaten.@WiiM Support - would you be able to check for an update on the timeline for the release of PEQs? What is also very important is the number of banks you will provide for the Pro (per channel), as I am considering the purchase of a miniDSP Flex for the purpose of applying PEQs for room correction.
The miniDSP provides 10 banks per channel.
Thank You!
Yeah I am curious too. I was just looking for the peq status as it was an important reason I choose to buy the WiiM over other streamers.I noticed that PEQ is not on the Roadmap for the Wiim Pro now. Is this an oversight? I very much hope not. It would be a great feature.
I think it's a mistake as the PEQ is still on the roadmap for the Mini.Yeah I am curious too. I was just looking for the peq status as it was an important reason I choose to buy the WiiM over other streamers.
Please let us know about your definition of 'shortly' ;-)PEQ will be provided shortly for both WiiM Mini and Pro. Please stay tuned and welcome your comments/improvement ideas.
GEQ is a subset of PEQ so you could easily implement it, but it would be very easy for Wiim to keep GEQ along with the new PEQ.They can remove geq in replacement on peq.
Can WiiM provide an update on the status of adding the feature of Parametric Equalization (PEQ) to the WiiM Pro streamer ?After some hard work, we believe PEQ (especially 3 bands one) works well for both Mini and Pro. Pro can support more bands PEQ due to more powerful CPU. We'll release it when passes our internal tests. Please stay tuned!
