AdieH
Nov 25, 2022
11
Hi all,
Cheers,
Adrian
Cincyret
Jan 12, 2023
10
When using the WIIM Android app or TIDAL Connect Android app or Audirvana Studio (Mac) my WIIM Mini transmits a loud pop/crack sound to my SMSL M200 dac when changing tracks manually. It also happens when I change from e.g. TIDAL to a radio station. My experience is pretty much the same as previous contributors to this thread.
So I tried connecting my WIIM Mini to an iFi Audio Spdif Purifier #2 via Spdif and plugged the Spdif Purifier #2 into my SMSL M200 dac via Coaxial. This set up has completely eliminated the loud pop/crack sound. Please note that the iFi Audio Spdif Purifier #2 is also a Spdif/Coaxial converter.
I have no idea whether other manufacturers' Spdif/Coaxial converters will produce the same positive result.
I have tried both the original version of iFi Audio's Spdif Purifier and the more recent #2 version. I was using them in other systems. They are both equally effective to completely eliminate the WIIM Mini's pop/crack sound with no appreciable loss of audio quality, at least as far as I can hear.
So if you have a spare Spfif/Coaxial converter why not try it and see if it works?
If I understand, you have Ethernet/Wi-Fi in and SPDIF/Toslink (optical) out. You then convert then the SPDIF to Coax with the ifi purifier. This solves your problem. Two questions (I may have missed the answer in a prior post): (1) Why don't you use the Coax out port on the WiiM? (2) In my case, I get intermittent crackling from both output ports (SPDIF & Coax) from the optical in port, so converting one to another probably won't work. My apologies (Optical in crackling-not audio out) if I've hijacked this thread.
GMcC
Jan 19, 2023
My WIIM Mini does not have an ethernet port. The Mini connects to the internet only via WiFi.
Unlike the WIIM Pro which connects to the internet either via ethernet or WiFi.
The WIIM Mini does not have a Coaxial output. Its sole digital output is via Toslink.
The WIIM Pro differs from the Mini by having both Toslink and Coaxial digital outputs.
When I connect my Mini's Toslink output to either of my iFi Audio Sdif Purifiers connected to my SMSL M200 dac solely via Coaxial the pop/crack sound is completely eliminated with no audible deterioration in sound quality. This configuration solves the problem.
However if I connect the Toslink ouput from either of my iFi Sdif Purifiers solely to the Toslink input of my SMSL dac the pop/crack is not eliminated. It stays exactly the same. This configuration does not solve the problem.
The iFi Spdif Purifiers have a Toslink and a Coaxial output. They both operate at the same time.
Please note that if I connect both outputs to my SMSL dac at the same time and select solely the Coaxial input on the dac (i.e. Toslink input turned off) the pop/crack sound is not eliminated. This configuration does not solve the problem. That may sound implausible but that's exactly what happens.
For the sake of confirmation I have repeated the above configurations a number of times, always with the same result.
When I substitute my SMSL dac for my iFi xDSD dac connected via Toslink to an iFi Spdif Purifier connected to the WIIM Mini via Toslink the pop/crack is completely eliminated. This configuration solves the problem. The iFi xDSD does not have a coaxial input.
I am not an audio/electronics engineer so I am unable to offer any explanation.
Cincyret
Jan 12, 2023
10
Thanks for such a detailed explaination. I see my questions were somewhat off topic. Now I understand (??). Thanks again.
onlyoneme
Oct 20, 2022
599
What about iFi xDSD connected directly to Mini?
AdieH
Nov 25, 2022
11
Thanks for this! Good to know there's a solution.
My only comment is that I feel I shouldn't need to buy another piece of hardware to fix the problem (this is not directed at you, but is a general comment).
Cincyret
Jan 12, 2023
10
What a great product & Support! The last firmware/app update fixed my crackling problen...crackling when connected to TV optical output.
I listened to 3 hrs on my Sony...No Crackling! Thank-you WiiM team!
Heres my setup:
Inputs: Ethernet & TV (optical)
Output: ONLY 1! - Coax to DAC (actualy I have a coax splitter to 2 DACs)
Sources: Qobuz Hi-res, and TV optical audio.
Everything works - Hi-res & TV - Speakers & Headphones
Minimal cabling - Ethernet, Toslink, Coax - one of each
This was just what I wanted & it's all working!
Thanks again!
GMcC
Jan 19, 2023
If my iFi xDSD is connected directly to my WIIM Mini there are no pops or cracks i.e. exactly the same positive result as when I connect the WIIM Mini to the xDSD via the iFi Spdif Purifier. Both configurations completely solve the problem. This also applies when using TIDAL Connect and/or the WIIM app (Android). I can switch from track to track, playlist to artist radio to radio station to Bluetooth etc all without any extraneous pops or cracks.
Unlike my SMSL M200 dac the iFi xDSD is powered from its own internal battery. The M200 is powered from its own power brick attached to the mains supply. I have no idea whether other battery powered dacs are also immune to the pops and cracks generated by the WIIM Mini. It may be worth investigating?
GMcC
Jan 19, 2023
I completely agree with you. Do all WIIM Mini's have this defect? Or only a faulty batch? In either case it is incumbent on WIIM to sort it out and not leave it to the purchaser to resolve at his own expense.
onlyoneme
Oct 20, 2022
599
It shouldn't matter because you use an optical connection between your devices.
I think that there are different situations here when popping appears, and different reasons. I consider spdif relocking as the main one because WiiM tends to force switching off/on its optical output on any manual track switching. Spotify Connect is not affected so I suggest to test the behavior here. If no popping with Spotify it could suggest that the main reason is mentioned spdif relock.
It depends on the audio chain if DAC relock is audible or not. Any device connected in the middle like iFi Purifier or spdif switch can change the observed behavior especially if it keeps its digital output always on regardless of the device connected to the input.
Klipscher
Nov 7, 2022
87
I think you’re right, in my case it’s spdif relocking since only happens when the bitrate changes. I looked into the iFi Spdif Purifier but not worth the price imho. Going try some other wallwarts thou to see if that might help.
Smartplug
Oct 20, 2022
257
Hello my friend klipscher, those ifi purifier are expensive nearing the cost of the pro. In my case I haven’t experience clicking/pop on smsl do 200, hopefully you will find solutions that won’t cost that much.
AdieH
Nov 25, 2022
11
UPDATE: This issue is now resolved for people who have a Denafrips Ares II with the 12th Anniversary Firmware update. Thanks to Klipscher for the heads up! It was just made available recently. It fixes the clicking and popping when switching between tracks using an optical connection.
However, I have now have a DAC that sounds completely different. Better in some areas: more detail, more resolving, great sound stage, thumpier bass. But the downsides: sharp, bright, glassy and fatiguing on my ears. The trade mark "warmth" of this DAC that I loved is now all gone. I'm going to give it a few more days, but am considering rolling back the firmware.
Thanks all for your help and discussion on this thread!
ADVICE: If you have a different DAC, seek out whether they have a firmware update.
onlyoneme
Oct 20, 2022
599
Do you use the same digital filter on the Ares II?
