tracks cut out/tracks skipped
mnock1976
Feb 20, 2023
6
Having issue where tracks cut out before they are done and advance to the next track, or sometimes skip over the track that should be next. This is in Tidal. Anyone experience this?
Funnily enough, I'm using Tidal playing on my tablet right now, and it just stuttered a couple of times half way through a track and then just skipped to the next track.
And as I'm typing this it just did it again!
Using Tidal Connect seems to have solved the problem, so it's their app that is the culprit. I contacted their customer support and I am sure they'll fix it sooner or later. Overall, I do find the user experience to be a bit clunky.
"so it's their [Wiim] app that is the culprit"
Well, maybe, maybe not.
Happened to me just using tidal on my tablet, nothing to do with wiim at all.
The tidal app then crashed not too long after that, then played fine for the rest of the day.
Hmmm. Tidal app just crashed for me as well. Buggy.
