P pieterv1 Major Contributor Joined Dec 14, 2022 Messages 831 Dec 26, 2024 #81 Maybe do some research and determine what you need before making such a fuss Glad you found a solution in the end
D Deleted member 11748 Guest Dec 26, 2024 #82 pieterv1 said: Maybe do some research and determine what you need before making such a fuss Glad you found a solution in the end Click to expand... you need to b 2 to fuss'!
D Deleted member 11748 Guest Dec 26, 2024 #83 but i still think, it would be cheaper to put a monitor output, and more conviennent, than a mini screen!
castalla Major Contributor Joined Mar 31, 2023 Messages 1,634 Location Comunidad Valenciana Dec 26, 2024 #84 What method/protocols does roon use to relay now playing screen.?
P pieterv1 Major Contributor Joined Dec 14, 2022 Messages 831 Dec 26, 2024 #85 castalla said: What method/protocols does roon use to relay now playing screen.? Click to expand... Wireless over Airplay/Chromecast
