WiiM Help Center Highlights - Jan 2025
RyanWithWiiM
WiiM Admin
Staff member
Sep 23, 2024
574
Explore our latest tutorials and guides, designed to enhance your audio journey and unlock new features. Here are all the big new articles and updated articles on our help center from January.
App/Software Usage​
Device Features & Audio Optimization​
  • How to Create a 5.1 Surround Sound Experience with Multiple WiiM Devices: Learn how to create an immersive 5.1 surround sound system using the WiiM Amp Pro and WiiM Ultra, which support Dolby Digital Audio. By connecting multiple WiiM devices in a multi-room configuration, you can enjoy a cost-effective and flexible setup ideal for movies, gaming, and music.
  • How to Set Up Bit-Perfect Playback on WiiM Devices: Bit-perfect playback ensures that the audio signal is transmitted from the source to your output device without any modifications, maintaining the original quality of the sound.
  • General Guide to Setting Digital Audio Output to PCM for Various TV Brands: Certain WiiM devices, including the WiiM Mini, WiiM Pro, WiiM Pro Plus, and WiiM Amp, support digital audio input in stereo PCM format. When connecting these devices to your TV via the Optical In or HDMI ARC interface, follow the general instructions outlined in this guide to configure your TV’s audio output to PCM.
  • Using the Group Audio Delay Setting for WiiM Multi-Room Audio: The Group Audio Delay setting is specifically designed for grouped playback in WiiM multi-room audio setups. It allows you to adjust audio delay for grouped devices to address audio-video synchronization (lip-sync) issues with TV inputs and improve multi-channel playback stability.
Dive Deeper Into WiiM Technology​
  • How to Connect Your WiiM Device to a Mobile Hotspot: If your home network is unavailable, you can set up a mobile hotspot to keep your WiiM device connected and running smoothly. This guide provides clear instructions to help you connect your WiiM device to a mobile hotspot effortlessly.
Troubleshooting​
User Manual​
We’ve updated user manuals for the following products: WiiM Amp Pro, WiiM Amp, WiiM Ultra.
Have Questions or Suggestions?​
We're here to help! Share your thoughts, ask questions or suggest new topics below.
Would you like any further adjustments?
Most of the links are failing for me even after clearing my browser cache on my iPad…
It would also be great if WiiM could reread the existing FAQs and correct and enhance those.
A common terminology across the articles should also be used and explained.
In many documents in the Help Center only the older device types are listed. This shall be updated to include all relevant devices.
The team is working on that! It's a bit slow going, but they're working on updating old ones too.
