Brantome
Moderator
Already acknowledged as a bug that will be fixed in the next app releaseNow the app not letting turn off wifi. I turn it off, go out and back in network settings and the wifi is again on. Annoying
Ive had only but troubles with tp link products. Go for asus or other good quality products.Hi Jd, sounds like a great idea if it helps anyone else. I’ve also sent a ticket out to the WiiM Team along with a system log for troubleshooting.
WiiM Pro Firmware - 4.8.504937
Internet Provider is Rogers (Ontario, Canada)
Internet/Lan Switch - TP Link Gigabit TL-SG105 (required because Internet Router only has 2 Ports)
All other services and devices on my home Lan or Wifi have absolutely zero connectivity issues. WiiM Home App has Wifi turned off.
As of my last post I went ahead and Factory Reset the Pro for the sake of troubleshooting, and went through the setup process again. Worthy of mention is that the SSID setting (Rename) is available again, and when using Airplay the Home App now shows the artwork from the song that is being played from Apple Music which the app did not do before.
I will continue to monitor the Pro behaviour and any Home App changes.
I suppose everyone’s experiences are different. But I’ve not had one problem with any wired device attached to either of the two tplink switches I have. Nor have I had any issues in the past with tplink wireless routers. They’ve provided years of trouble free service. D-link on the other hand (for me) have been quite problematic.Ive had only but troubles with tp link products. Go for asus or other good quality products.
WiiM have said they’re taking some time to concentrate on fixing bugs and that they were employing a gatekeeper to try to minimise re introducing bugsThis probably reason wiim hardly get any update unlike before every 2 weeks. It fix something and break something.
Stupid question - I know - tried a new cable?Now the app not letting turn off wifi. I turn it off, go out and back in network settings and the wifi is again on. Annoying
Yes installed 1 week ago a new lan cabel, again reset device, then there was a software/firmware update.. a now 1 week no disconnectStupid question - I know - tried a new cable?
(First rule in Microsoft certification “check the cable” )
Mine has worked on Ethernet since day one…Not yet plucked up the courage to plug in the ethernet cable...
Thought you were still waiting to get yours in Blighty.Mine has worked on Ethernet since day one…
I’ve had a pre release unit to test since the end of Nov’22 but given I’ve been advocating its use/purchase since then on several UK forums, I’ve actively been pushing for its actual availability hereThought you were still waiting to get yours in Blighty.
Or is today day one?
