Upstairs-Room
- Joined
- May 14, 2023
- Messages
- 14
Hi, my WiiM Pro is connected to a Linn Majik DSM /2 (2015 Variant) via the supplied TOSLINK optical cable.
When I start Spotify and select the WiiM Pro as the destination, there is a shockingly loud 1 second volume blast, even if the Linn DSM volume is set to 0 (zero). This cannot be good for the speakers, let alone for neighbor relations...
Thanks in advance for any pointers...
- The WiiM Pro is set to fixed volume output (100%) which I have read is the optimal setting for this kind of setup.
- Audio setting is 96 khz / 24 bit.
- Internet connection is via ethernet and Wifi is turned off.
- The WiiM Firmware is always the latest as I reboot the WiiM daily to check for updates.
