윔미니, 윔프로를 사용하고 있는데 아침 기상시간에 맞춰서 알람 기능을 일요일을 제외한 월, 화, 수, 목, 금요일까지 06시에 맞춰서 사용하고 있습니다만 이상하게도 설정하지 않은 토요일에도 알람이 작동됩니다
일요일은 정상적으로 작동되지 않습니다
다른 사용자들도 저와 같은 현상이 있는지 궁금합니다
Yes, I understand your problem. Please contact support in the Feedback section of the settings menu of the WiiM home app. The logs of your device will be sent to help you resolve.
I don't know if my device has the same problem as yours because I don't use alarms.
You can also create five alarms that go off at 6 a.m. each on Mondays, Tuesdays, Wednesdays, Thursdays, and Fridays to see if they work as you want.
On Mondays, Tuesdays, Wednesdays, Thursdays, and Fridays, the alarm is normally activated at 6 o'clock, so you can wake up early
But the alarm goes off even on Saturday when the alarm is not set
Please refer to the picture I set up
