slartibartfast
- Joined
- Apr 18, 2024
- Messages
- 3,786
There is. Didn't you read all 18 posts before yours?No mention of any Fosi products, curious!
According to the reports it's not class A/B but class B with lots of feedback.Topping B100 or B200. Class A/B monoblock with SNR / DR > 140dB.
Thanks again for all input. Here are my updated thoughts:No mention of any Fosi products, curious!
Just posted an update. Not sure where that post shows up, I am typing on phone. ThanksHas the OP made any headway with amp selections? Just curious.
WiiM amp pro would be a great choice. Just remember you’ll need an external phono preamp for your turntable.Thanks again for all input. Here are my updated thoughts:
I am sympathetic to the comment about having an integrated amp that has its own volume.
I dont want to have to deal with having to figure out which piece (Ultra or Amp) to plug the pieces into (turntable, CD, speakers, sub).
I am leaning to the Wiim Amp Pro bc it is same investment as many of the exotic brand suggestions and at least I know: they will work well together, hopefully everything is easily configured in app and near universal good reviews of wiim.
Just seems what I want is a combination product - a Wiim Amp Ultra???
I am not completely decided yet (will probably wait to snag a Black Friday discount anyway) so, if you have a pure power box that simply plugs into the Ultra but lets the Ultra lead in everything else, let me know. Reminder, I am a fairly smart cookie but started from a very low knowledge level in hifi. I enjoy learning the detail just make sure you start with the base explanation so I can understand.
Fcuk!!!! Why is this so complicated? What is this “external phono preamp” and where do I research and buy? Do I need an “external CD player preamp”? Of course, I am not blaming the messenger, I am just frustrated.WiiM amp pro would be a great choice. Just remember you’ll need an external phono preamp for your turntable.
A cheap oneFcuk!!!! Why is this so complicated? What is this “external phono preamp” and where do I research and buy? Do I need an “external CD player preamp”? Of course, I am not blaming the messenger, I am just frustrated.
The Amp Pro does pretty much everything the Ultra does but it doesn't have a dedicated input for a turntable. You would need a phono preamp to go between the turntable and the amp line in to provide gain and RIAA equalisation.Fcuk!!!! Why is this so complicated? What is this “external phono preamp” and where do I research and buy? Do I need an “external CD player preamp”? Of course, I am not blaming the messenger, I am just frustrated.
Sorry didn’t mean to stress you out. I know you wanted to keep it simple. You’re turntable may have a preamp built in to it already. If not you will need a separate phono preamp. Your cd player probably has a digital output. Then you can connect your cd player to the digital input of the WiiM amp.Fcuk!!!! Why is this so complicated? What is this “external phono preamp” and where do I research and buy? Do I need an “external CD player preamp”? Of course, I am not blaming the messenger, I am just frustrated.
Add a "no" in the right place.OP said he already owns the WiiM Ultra so there's need for him to buy an external phono preamp - regardless of the amp he chooses.
Amen.In my opinion it's still a bit odd to pair the Ultra with the WiiM Amp. If you already own the Ultra, you could do with a simple poweramp without all the smarts, controls and extra inputs and outputs of the WiiM Amp. The Ultra is designed to be used as a perfectly capable preamp. If the poweramp has a 12v trigger input, you can control it with the Ultra's trigger output, allowing for a completely automated setup.
He could always return the UltraErgh was getting late
No need for a phono preamp indeed!
I dont want to return the Ultra. I love the screen for settings and ALBUM ART!!!! My som will love it too.... yes if the Ultra is still within the legal return period, maybe the WiiM Amp + cheap external phono preamp would be the way to go!
Indeed the Ultra, paired with either of these amps will be the nicer setup. Both amps will definitely do justice to your speakers. Audiophonics is the cleaner solution as explained above. Enjoy!!That's pretty clear. Except for two things: price range and what part of the world do you want it delivered to.
A pair of "FOSI AUDIO V3 MONO Class D Amplifiers" has plenty of power, shows no load dependency and could drive even more power hungry speakers. The only "configuration" is making sure that the gain switch at the back is set to 25 dB (might even be from the factory).
They can reliably switch on and off with the WiiM Ultra by means of their auto-on feature.
The pair of monoblocks will set you back around 250€ plus sales tax.
The "AUDIOPHONICS MPA-S250NC RCA Power Amplifier" can do everything the V3 Monos can, just better and in one single housing (where the V3 Monos are two mono locks with either one common 10 A power brick or two 5A power bricks, so 3 or 4 boxes in total).
It can switch on and off in synch with the WiiM Ultra by means of a single mono trigger cable.
The price is 400€ plus sales tax for the stereo amp.
Hello all,Has the OP made any headway with amp selections? Just curious.
