Bit depth always 16bit optical/hdmi
kinghol
Aug 15, 2024
9
on Optical and HDMI the Wiim app always shows 16bit depth but when playing with eg. Tidal connect there will be a change based on song quality.
At first I thought it was an error config from my Linux PC via optical but trying this on my TV via hdmi there will always be 16bit!
Sound playing perfectly fine for my old ears so it is only a question out of interest!
Cheers
Cheers
Noticed this as well, haven’t researched or investigated why, but if someone has a suggestion or advice that would be awesome.
Tested Apple Music, and Tidal, while playing Tidal was displaying 24 bit, however, in the WiiM App - It still displayed 16 bit
Using my PC, through optical, it's set to 24/192, same, WiiM App displays 16/44.
I'm digging through the ol'Google but it's rather hit and miss at this stage.
Edit
Worked through my PC’s sound playback settings
Choosing 16bit/44 and onwards changes the WiiM App instantly, then, moving over to 24 bit, it changes over (sound loss in windows) but the WiiM App stays with the 16 bit - So I’m leaning to an app issue not displaying correctly
The 16/192 (image attached) is 24/192 in windows. the 16/96 is 16 bit in the sound panel
Edit
Hmm login into my Tidal account in WiiM app and playing a song did display the respective bit/freq
I have the same issue with Apple Music from usb-c -> toslink adapter. The bit depth is always 16 bit regardless of the actual track. The sampling rate changes correctly up to 192khz
It's a data header issue. WiiM displays 16 bits depth if it's not told otherwise. The actual bit depth is what it receives, which always is 24 bits on optical.
This winter there were complaints that WiiM was displaying 24/44.1on optical from CD players, so WiiM changed the display to 16 bit.
