Introducing WiiM Sub Pro: Experience Bass Like Never Before
🔥 WiiM expands into deeper sound! Meet WiiM Sub Pro, our first-ever subwoofer, designed from the ground up to deliver deep, distortion-free bass with AI-driven precision. Whether tuning your music, movies, or gaming setup, this sleek sub delivers precision through its 8-inch driver and Class-D amplifier, boasting a frequency range of 25Hz–200Hz which adapts to your space for optimized performance.
After years of perfecting streaming and amplification, we listened to our community and built a subwoofer that enhances your audio setup with clean, powerful bass and seamless wireless connectivity.
AD_4nXfYN4BgslKzRUjXM6VFt6p0Fc6uHIGOsa87gMd-OkdMA1hWqWeszI_RlVaUs281-laCb386CGUYJBa7aSAHmPcg1GYJw1MYEkKDuBD4sgn9i3TExHCNxi6-GcelqgzUgMBqSEwr
What makes WiiM Sub Pro stand out?​
  • Reliable wireless connectivity: Supports Wi-Fi 6E, 802.11 b/g/n/ac/ax 2.4 GHz, 5 GHz, and 6 GHz., Bluetooth 5.3 and RCA input enabling seamless connection to a wide range of audio setups.
  • Smart power management: Automatically enters standby mode and detects RCA signal or plug input to optimize energy use and simplify daily operation.
  • Precision sound enhancement: Includes Auto Room Correction for both the main speaker and subwoofer, ensuring optimized bass performance based on your room’s acoustics.
  • Flexibility of WiiM connectivity: Connect the Sub Pro with any WiiM streamer, amplifier, or speaker!
Seamless Integration with WiiM & Third-Party Devices​
Works flawlessly with WiiM streamers, amps, and speakers for tight bass performance. Pair WiiM Sub Pro with WiiM Sound, or enhance your existing WiiM setup for deeper bass and dynamic home audio. Have a WiiM streamer or amplifier without a subwoofer output? The WiiM Sub Pro can sync with them wirelessly to bring room filling sound to your setup!
Supports third-party devices via analog RCA mono input.
Key Features:​
  1. Powerful & Distortion-Free Bass
    1. 250W of deep, clean bass with less than 1% THD+N, delivering an immersive experience for movies, music, and gaming.
  2. AI-Driven Room Calibration for Precision Bass
    1. RoomFitâ„¢ Auto-Calibration takes precise acoustic measurements, adjusting bass to match your room size, speaker placement, and listening position.
  3. Next-Gen Wireless Connectivity
    1. Wi-Fi 6E for a low-latency, high-bandwidth connection, ensuring stable and interference-free performance.
    2. Bluetooth 5.3 with LE Audio for flexible connectivity with supported devices.
  4. Advanced App Control for Custom Sound Tuning
    1. The WiiM Home App allows for precise EQ adjustments, crossover tuning, phase control, latency customization, and subwoofer level adjustments.
  5. Elegant, Acoustic-Optimized Design
    1. Premium cabinet construction with custom-designed woofers, engineered for vibration-free, resonance-free bass even at high volumes.
    2. Sleek, modern aesthetics that blend effortlessly into any home décor.
  6. Seamless Integration with WiiM & Third-Party Systems
    1. Designed to work flawlessly with WiiM streamers, amplifiers, and speakers for a cohesive audio ecosystem.
    2. Connects easily with third-party devices featuring a subwoofer output, ensuring broad compatibility.
  7. Always Improving with Firmware Updates
    1. Regular over-the-air updates introduce new features, enhancements, and performance optimizations, keeping your system at the cutting edge.
Tech Specs​
🔊 Speaker: 8-inch driver | 25-200 Hz range | 104 dB SPL sensitivity
🔌 Connectivity: Wi-Fi 6E | Bluetooth 5.3 | Ethernet | RCA input
🎚 Subwoofer Control: Adjustable crossover frequency, level, phase, and latency
🎛 EQ: 10-band parametric EQ + automatic room correction
Dimension: 15.7 x 11.8 x 12.7 inches (399 x 301 x 322 mm).
Weight: 35.2 lbs (16 kg).
Pricing & Availability​
WiiM Sub Pro launches in Q3 2025 on Amazon and select retailers. Stay tuned for pricing details, we'll announce them when the product becomes available. Full details at www.wiimhome.com.
🎶 Ready to feel the difference? Let us know how you'd use WiiM Sub Pro in your setup!
Hi @Wiimer,
Apologies for the incorrect information provided by Ryan.
You can wirelessly add WiiM Subs to a WiiM streamer or amplifier. We also support connecting both a wireless WiiM Sub and a wired subwoofer to the same WiiM streamer or amplifier simultaneously.
But can one sub handle bass from left channel while the other handle bass from the right channel? Or are they all receiving the same LFE signal?
-Ed
Hi @Wiimer,
Hi @WiiM Team,
Thanks for your reply.
Let me check again.
Is it possible to wirelessly connect 2 WiiM Sub pro's to a WiiM amp Ultra, and have them work as stereo(or mono) subs?
(This should be possible if the WiiM Sub is linked to the WiiM device with MRM.)
Or are there 1 wireless and 1 wired sub that can be connected?
"You can wirelessly add WiiM Subs [plural] to a WiiM streamer or amplifier" implies they can be added in a group like other wiims and you can reach bass nirvana with as many subs as you like :)
Indeed, simple enough question - with the sub(s) in a group, does the wiim app allow each sub to be 'LR', 'L', 'R' like other wiims?
That's exactly what it is.
Thanks for expressing exactly what I want to ask 😄.
(Perhaps the problem, if there is one, is whether I can manage the bass on 2 Sub's at the same time...)
Wow. Great news! Was thinking about adding a second sub to even out the frequency response in the lows throughout my room. Will I be able to pair it with my already existing sub and Wiim Ultra? The Sub out on the Ultra is already in use, thus I wonder how it will work when one sub is connected by wire and second wirelessly?
@WiiM Team @WiiM Support
Does this mean Pro, Pro+, mini will have bass management capability (lowpass / highpass filter, and time alignment) when connected with Sub Pro?
Hi jed1, team
Exactly! You can wirelessly pair the WiiM Mini, Pro, or Pro Plus with the WiiM Sub Pro, which handles bass management just like a wired sub-out connection. For stereo setups with two streamers, multiple Sub Pros can be paired as well. The WiiM Home App supports automatic calibration for time alignment and room EQ, giving you flexible control and customization options.
Hi jed1, team
I read the question / answer differently, conflictingly and confusedly!
"Wirelessly pair" - meaning what? A sub can only be pired with a single other wiim at a time, and not be added to a group / many persistent groups like other wiims?
"...with the WiiM Sub Pro, which handles bass management" - so the sub itself handles the bass management?
"...just like a wired sub-out connection" - so the paired wiim device handles the bass mangement?
"For stereo setups with two streamers, multiple Sub Pros can be paired as well." - what does that even mean?
"The WiiM Home App supports automatic..." - so each sub is a device in the app, or just a sentence about RoomFit in general?
How many subwoofers can play down to 25 Hz at 96 dB with 1% THD+N? :unsure: Certainly no sub with a single 8" driver ...
I agree. It's just that's what the initial specs are suggesting.
Though to be fair, when we usually discuss such things, we're aiming at a higher volume than 96dB, I suppose.
Hi, I've got two wireless speakers which onboarded WiiM Mini streamers per speaker. I can playback stereo (L + R)/multiroom on WiiM Home app and Airplay. Do I need to purchase an extra streamer if I want to plug the new Sub Pro ?
The product is not available yet, but as far as I understand the WiiM Sub Pro can form a group with WiiM devices. But I didn't understand your current setup yet
How do you play from the WiiM Mini(s) to the wireless speaker(s)? Which connection technology?
