wiimamp user
- Joined
- Jan 12, 2024
- Messages
- 533
But please stay so excited for your amp, even if you can not really hear a difference between hires and CD quality ;-))Thanks this works
Was that a typo and should read 2.9.1.240408?My Android App was updated last on 08.04.2024 to 2.9.1.2408408
Sorry, yes. You're right. Shame on me, too thick fingers ;-)Was that a typo and should read 2.9.1.240408?
But i think can hear a difference..But please stay so excited for your amp, even if you can not really hear a difference between hires and CD quality ;-))
I don't even care ... for the moment, at least. I first want the WiiM Home App to be fixed. Then I might consider testing, but certainly with my Lyngdorf first and the Wiim second.But i think can hear a difference..
Or is it the placebo effect
I can hear it..(my opinion.)
Does this also stop you using "max" from the tidal app when streaming to the WiiM?My Apple apps have also been updated today, and reflect today’s changes, with Max now available, and the Current subscriptions has now changed from HIFI to TIDAL.
The WiiM home app has not changed, and still shows Subscription as HIFI.
There’s currently no way to select Max, so perhaps the WiiM app needs an update to resolve the issue.
I can use Tidal Connect to my WiiM devices to access the Tidal Max Flac content.Does this also stop you using "max" from the tidal app when streaming to the WiiM?
I logged in and out a few times (for curiosity only) alarmed by the trumpets of Jericho here ;-)My WiiM app still shows Tidal max as before and allows up to 192khz. I will not try to logoff, since I remember something about to loosing features when trying to relog after changes not yet managed. Maybe was for Qobuz or whatever but why risk?
The music that I’m listening was Madonna and still mqa.
So can you confirm that your Tidal Account Subscription hasn’t changed from HIFI Plus to TIDAL in the WiiM app.I logged in and out a few times (for curiosity only) alarmed by the trumpets of Jericho here ;-)
No problems, the WiiM app shows still HiFi Plus and everything works as usual.
YESSo can you confirm that your Tidal Account Subscription hasn’t changed from HIFI Plus to TIDAL in the WiiM app.
As it will be forever, I bet ;-)The music that I’m listening was Madonna and still mqa.
There will still be MQA albums in their catalog as some record labels only produce that (2L is one iirc). Even Amazon and Qobuz have MQA albums as a result but ignore the MQA info.As it will be forever, I bet ;-)
I am infamous for ignoring infos ;-)There will still be MQA albums in their catalog as some record labels only produce that (2LS is one iirc). Even Amazon and Qobuz have MQA albums as a result but ignore the MQA info.
Since you mention it yourself ...OK it's an useless thing but it's nice to know also...
Quite sure I mentioned it before ;-) but I've heard it from John Darko in exact this context: "To see is to saviour."Since you mention it yourself ...
Would it keep you from listening if you knew the exact bitrate in advance? I know my own answer to that question.
And I wonder why they implemented it like this.
