WiiM Ultra Firmware v5.2.714249 - Apr 18, 2025
Please review the WiiM Ultra update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
5.2.714249​
Release date:
4 / 18 / 2025
What's New:
  1. Smarter HDMI ARC: Your WiiM Ultra will no longer act as a TV speaker when not in HDMI mode—giving you more control. Learn More
  2. DLNA Casting: Stream audio to any DLNA-enabled speaker for flexible whole-home listening. (Let us know if you run into compatibility issues!) Learn More
  3. Track-End Sleep Timer: New option to pause playback at the end of a track—perfect for winding down. (Requires app update: iOS 3.1.9 / Android 3.1.8)
  4. Auto-Resume Playback for Soundtrack: Playback resumes automatically after OTA updates, reboots, or network reconnections.
  5. Enhanced VU Meter: Smoother, more responsive visual performance.
  6. Group Volume via TV Remote: Control group volume directly using your TV remote.
  7. Screen Display Improvements: Input alias names now display correctly on the device screen.
  8. Wi-Fi Boost: Faster network scanning and connection times.
  9. Roon Sync: Improved multi-room sync for Roon users.
Bug Fixes:
  1. Amazon Music: Fixed playback issues for Prime users.
  2. Spotify Presets: Resolved unexpected ungrouping during group playback.
  3. TIDAL: Fixed skipping, playback errors, and incorrect quality cap on 24-bit/96kHz optical/coax outputs.
  4. Qobuz: Fixed track-start issues after skipping and unexpected playback jumps.
  5. Radio Paradise Enhancements: Resolved issues with track repetition during playback and fixed login failures caused by special characters.
  6. Alarm Fix: Resolved issues affecting alarms in Daylight Saving Time zones.
  7. General Performance: Stability improvements and behind-the-scenes optimizations.
I requested removal from 1.56 chromecast. Received the penultimate version 5.2.711448 with 1.68…
It does not cast correctly from the Qobuz app. 96kKz gets transcoded to 44.1. Time to go back to 1.56 again…
Bummer. Thank you for giving it a try this quick.
Checked it twice, second time after full power cycle. Bummer indeed. Waiting now for a version with 1.56.
It surprises me that others claim no issues.
Has something changed regarding ARC? It has worked perfectly for months but since this update, after some time switched off, there is no sound unless the Ultra is rebooted.
Yes, see release notes:
I already feared it was going to cause more issues than it would do good, but I haven't received the update yet.
I'm concerned that my TV will no longer play through my Ultra to my speakers via HDMI cec which has worked fine to this point. It just works every time whatever the Ultra has been set to. No manual intervention necessary. Can anyone confirm that will still be the case with this new update?
Also can I stop the Firmware update if I don't want it?
The option (which has been there) didn't do anything (useful) so far. As long as the correct setting still works as before, there should be nothing to worry about. It's a one-time setting. Once you have it according to your needs, no further manual interaction is required.
Hi jamster,
Sorry for the inconvenience caused.
Please help us investigate by sending feedback through the WiiM Home app: go to the More tab and tap Feedback. Once we receive your report, our engineers will look into it promptly. After that, we will assist in reverting your device to the previous firmware version so you can check if the issue still persists.
@WiiM Team
Is an option without any transcoding (aka bitperfect) finally implemented for DLNA casting?
Hi onlyoneme,
Currently, we do not support bit-perfect playback for DLNA casting. However, I will forward this feature request to our engineers, and they will assess how to implement it.
Hi onlyoneme,
Ok. If I remember correctly it was promised at the very beginning as the lossless alternative for AirPlay.
Doesn’t Audirvana use DLNA? No transcoding for me when transmitting to Ultra (all the way to 192kHz).
I am now testing QConnect so the beta firmware has Chromecast 1.68. And now I wonder if the Chromecast issues I found with 1.68 are an issue with the current (non-connect) Qobuz apps. Perhaps they were. not updated to support Castlite?
Has anyone received this update?
It seems to be taking a very long time this time 🤔
