LtMandella
- Joined
- Oct 30, 2023
- Messages
- 20
I did a search and found nothing so:
I would like to use my FIIO M11 Plus as an external DAC but the FIIO only has USB for wired input. It has no s/pdif COAX or OPTICAL inputs. So how would I use that player as an external dac? I believe the FIIO supports airplay (not sure about airplay 2) and possibly chromecast if using a 3rd party player app. I use a WIIM pro as the master in main listening room (where I would like to use the FIIO as the DAC) and a WIIM mini as a slave for a multi-room listening.
Anyone have any ideas?
[[edit]]
According to "new feature" in wiim blog, looks like I can send (cast using airplay) the digital music stream from my wiim pro to my M11 Plus for use as external dac. And hopefully the synced mini in another room will still work as wireless slave. Correct?
And perhaps the reverse? Can I use the M11 Plus as the player in one room feeding my main system, and use airplay to cast the music stream from the M11 Plus to the two wiim devices as synced slaves, so I can have 3 room multi-room listening with FIIO in one room, and the two wiim devices in two other room systems?
thanks!
LT
[[edit]]
thanks!
LT
