Chromecast broken? Upon review Not a WiiM issue
adias
Jan 3, 2023
338
It seems that Chromecast is broken. If I cast from an app like Global Player choosing Chromecast, not Airplay, it starts playing but if I close the Global Player app the WiiM app stops playing. With Chromecast, WiiM should continue.
It seems to be an issue with the Global Player running in iOS. Other apps such as BBC Sounds work fine.
I created a ticket via Feedback.
Edit - disregard as this is not a WiiM issue.
Almost sounds like Global Player is not really using Chromecast then, but Airplay instead.
You should be able to verify (or falsify) that using the Google Home app.
