KKBox and Chromecast Audio
blacdot
Jun 14, 2023
1
I'm using Pixel 3A while WiiM Pro on ethernet.
All Music can play normally in the phone via KKBox. But once I try to cast it to chromecast, it keeps loading. I'm 1.5m away from the chromecast receiver.
It works well for a few songs but not for rest of the songs.
I'm not sure whether it's KKBox or Chromecast/WiiM issue.
Is it because having phone on Wifi and WiiM on ethernet an issue?
If I use Wifi on WiiM pro, I believe the network connection is not stable/fast enough for streaming.
Wifi or Ethernet connectivity shouldn’t be an issue unless you normally have an issue with your wifi. You could try using just wifi on your Pro but I don’t think that’s your issue. Can you use ChromeCast to your Wiim for any other music service?
You may want to submit a ticket thru the feedback section in the WiiM Hime app when you hit this issue.
