Optical Input iPhone volume control
May 16, 2023
11
Hi just got a wiim pro - all good great little streamer using coax out to my speakers
I mainly stream Spotify from my iPhone and volume works well there - when I use iPhone volume buttons the little wii icon appears and it works well
With TV however - optical input into the wiim - the volume control doesn’t work when the app is closed. The iPhone volume slider icon goes up and down but no effect
I have to open the app each time I want to change TV volume which is a bit annoying. With the app open - the iPhone hardware buttons work fine as well as the app slider.
Any setting I can do in the wiim app or iPhone settings?
I have a remote control on the way anyway but still would like to fix this small quirk :)
Any help much appreciated
Kind regards
Jamie
