WiiM Team Administrator Staff member Joined Oct 19, 2022 Messages 351 Oct 25, 2022 #1 Open thread to share anything related to WiiM Mini
WiiM Team Administrator Staff member Joined Oct 19, 2022 Messages 351 Oct 25, 2022 #2 Enjoying the latest firmware update? 4.6.432755 (Latest) Release date: 10 / 17 / 2022 This update involves the following: Performance Improvements: Spotify playback smoothness SPDIF output becomes idle when system stops play in two minutes Bit perfect output for LinkPlay multiroom for 48k Hz or lower, 16-bit content Amazon Music memory optimization for 24/192k audio Select the best AP for the mesh network Bug Fixes: Keep the BT Source mode when the device reboots Slave speaker volume issue for the Spotify multiroom EQ clipping when using the fixed volume option or playing music in high volume Other bug fixes and performance improvements New Features: Add movie and gaming EQ modes Radio Paradise Options to set the SPDIF idle timeout SoundCloud Beta
O onlyoneme Major Contributor Joined Oct 20, 2022 Messages 2,320 Oct 26, 2022 #3 Unfortunately not at all due to distortions I can measure with that FW.
S SiR Major Contributor Joined Nov 7, 2022 Messages 54 Nov 7, 2022 #4 Will WiiM Mini be replaced by WiiM PRO or WiiM Mini will be available simultaneously ?
WiiM Team Administrator Staff member Joined Oct 19, 2022 Messages 351 Nov 7, 2022 #5 SiR said: Will WiiM Mini be replaced by WiiM PRO or WiiM Mini will be available simultaneously ? Click to expand... WiiM Mini won't be replaced by WiiM Pro. WiiM Mini will still be available.
