WiiM Pro Plus API, NET::ERR_CERT_AUTHORITY_INVALID
rexx
Feb 27, 2024
I have a little program that is trying to communicate with my WiiM Pro Plus.
When I send the url
https://192.168.0.224/httpapi.asp?command=getPlayerStatus
I get no response.
When I aim my browser at the same url, I get
Your connection isn't private​
Attackers might be trying to steal your information from 192.168.0.224 (for example, passwords, messages, or credit cards).
Is there something obvious I am missing...?
I tried http (not https) but that doesn't work either.
Looks like self signed cert. Depends what library you’re using there is a way to disable verification. In Python it will look like
Python:
requests.get('https://example.com', verify=False)
Thank you. I was able to switch from using Windows Msxml2.ServerXMLHTTP to MSXML2.XMLHTTP GET which has the verify option you showed.
