cc_rider
- Joined
- Oct 20, 2022
- Messages
- 1,429
IOW, you're completely clueless. I thought so.Huh.....i never mentioned the remote. I dont even have the remote control......
Are you being serious? Have you never heard of DDC devices such as the Gustard U18, Audio-GD DI-20, Denafrips IRIS? These devices de-jitter and re-clock the digital presented to the DAC. The DI-20 also allows the SPDIF output of the Wiim Pro to be converted to i2s into my DAC.@Vangelo51
Is your DAC so poor at proper handling of spdif stream that it needs a special "cleaning" routines?
Its called sarcasm which seems to have passed you byIOW, you're completely clueless. I thought so.
...and in a properly conducted DBT, I guarantee the "huge difference" would go away, unless the DDC is adding distortions.Are you being serious? Have you never heard of DDC devices such as the Gustard U18, Audio-GD DI-20, Denafrips IRIS? These devices de-jitter and re-clock the digital presented to the DAC. The DI-20 also allows the SPDIF output of the Wiim Pro to be converted to i2s into my DAC.
Now you may believe such a device is not necessary, and i2s makes no difference, but I happen to believe in my system they make a huge difference.
I'm very serious but you didn't answer to me. I'm aware of reclockers like the ones offered by Mutec, and that is why I've asked my question.Are you being serious? Have you never heard of DDC devices such as the Gustard U18, Audio-GD DI-20, Denafrips IRIS? These devices de-jitter and re-clock the digital presented to the DAC. The DI-20 also allows the SPDIF output of the Wiim Pro to be converted to i2s into my DAC.
Not sure why you feel the need to troll me, like you are a superior being. Let me enjoy what I enjoy in my ignorance. I dont need to be educated by you............and in a properly conducted DBT, I guarantee the "huge difference" would go away, unless the DDC is adding distortions.
Ok....my DAC is fine.I'm very serious but you didn't answer to me. I'm aware of reclockers like the ones offered by Mutec, and that is why I've asked my question.
This OAs do not like headwind, it has to do with egoOk....my DAC is fine.
There is nothing to repair in the digital stream if its quality is good enough to be handled properly by a competent receiver. WiiM signal is quite good, so maybe something wrong is with your DAC. May I ask the name of your device?Ok....my DAC is fine.
