Pcryan5
I am looking at Amazon to replace Tidal. Is it accurate that Amazon does not support HD streaming via WiiM Mini unless it is to a Amazon Studio device? (I use Devialet)
thanks!
P
thanks!
P
Must be. If I remember later on, I’ll try it on an older android phone I have (Honor 10) and my fire hd tablets. I’m currently using a Motorola Edge 30 Fusion which is only weeks old.This is what I get.
No, that’s the Android Amazon Music app v 22.15.1 OTA (#150114) on my Motorola phone here in the UKYou have different interface? Arent You using alexa app?
Motorola is still in the game? I thought they stopped producing smartphones.No, that’s the Android Amazon Music app v 22.15.1 OTA (#150114) on my Motorola phone here in the UK
No, they’ve quite a range - the model I bought came out in Sep ‘22.Motorola is still in the game? I thought they stopped producing smartphones.
Also OK on my 4yr old Honor 10 which is based on Android 10, although I did briefly get the spinning wheel. My Motorola is based on Android 12.Must be. If I remember later on, I’ll try it on an older android phone I have (Honor 10) and my fire hd tablets. I’m currently using a Motorola Edge 30 Fusion which is only weeks old.
In the WiiM app, yes, but you can still search for them in the WiiM app Amazon music page, or access them from the Amazon Music app itself and cast.Btw. Playlist issue looks to be permanent
I can't cast in Poland without having british address. What do You mean "wiim app Amazon music page"?In the WiiM app, yes, but you can still search for them in the WiiM app Amazon music page, or access them from the Amazon Music app itself and cast.
Ah yeah, there is that drawback in regions where AlexaCast isn’t supported. Re the Amazon music page in the WiiM app, I’m referring to the find icon under browse/amazon music in the Wiim app.I can't cast in Poland without having british address. What do You mean "wiim app Amazon music page"?
I tested Tidal, Apple against my existing subscription to Amazon.I am looking at Amazon to replace Tidal. Is it accurate that Amazon does not support HD streaming via WiiM Mini unless it is to a Amazon Studio device? (I use Devialet)
thanks!
P
I have the UHD set to on in the alexa device settings and when i try to play thru the amazon app it shows it is casting to the mini and shows up to 192 on my dac but it plays a few seconds then the sound cuts out. Any suggestionsAs the Wiim team have confirmed in a thread here somewhere, there is no difference between using Amazon within the Wiim app or casting from the Amazon app - both will play files at up to 192, as long as you've chosen UHD in the Alexa settings and have not restricted your Wiim's output resolution.
Does the same happen if you cast, for example, to an amazon echo device? If not (or if you can't try that), submit a ticket thru the feedback section so that WiiM can inspect your log file for clues as to whyI have the UHD set to on in the alexa device settings and when i try to play thru the amazon app it shows it is casting to the mini and shows up to 192 on my dac but it plays a few seconds then the sound cuts out. Any suggestions
No. I just cast amazon to my echo show device and it plays fine. It just cuts out when i play thru the mini. Thank you for the response.Does the same happen if you cast, for example, to an amazon echo device? If not (or if you can't try that), submit a ticket thru the feedback section so that WiiM can inspect your log file for clues as to why
Try reboot your mini.No. I just cast amazon to my echo show device and it plays fine. It just cuts out when i play thru the mini. Thank you for the response.
How do you reboot the mini without having to set it all up againTry reboot your mini.
How do you reboot the mini without having to set it all up againUSB
Thanks. I tried unplugging the electricity and plugged it back in but didnt fix it.Unplug the USB cable.
or
Wiim app > Device > WiiM mini > Reboot
