Thank you Maurizio. That's what i tought first but after reading all the comments/review about the WiiM amp, i thought that this more an amp about 1500eur....So i try combine old and past but not sure it's a good ideaI have the B&W 603S2 and I can say that they are absolutely fantastic. I've never heard the KEFIQ70.
I would like to add one thing. Given the quality and cost of the B&Ws, I would think, I would suggest combining them with a real HiFi amplifier, certainly not with an amplifier like the Wiim.
B&W deserve a much better amplifier.
Remember the golden rule. Your system will sound like the weakest link in the chain. €2,000 speakers with a €369 amplifier?
Unfortunately they will sound for €360
Of course this is only my personal opinion
A system sounds like the speakers. There are no other rules. If you like spending money on theoretical differences, go ahead, but you shouldn't scare other people into thinking they also need to spend way more.Your system will sound like the weakest link in the chain
That's only true of very good amps who are both transparents and immune to speaker impedance fluctuations across the frequency range. Yes in this case the speaker is all. However lots of amps, while not 'broken' per se don't actually have those characteristics.A system sounds like the speakers. There are no other rules. If you like spending money on theoretical differences, go ahead, but you shouldn't scare other people into thinking they also need to spend way more.
I have a pair of Focal Chorus 826V, which are actually very similar to the B&W model mentioned here, and they sound excellent even on the tiny little Wiim Amp. I've never heard (or, in fact, even seen) Kef speakers, but if they sound good with a € 3700 or € 37000 amp, they'll sound just as good with a € 370 amp. If an amp makes your speakers sound bad, the amp is broken.
(Source: https://www.hifinews.com/content/bw-603-s2-anniversary-edition-loudspeaker-lab-report)... but the loading will not be a walk in the park for all amplifiers. Specifically, there's a broad sub-4ohm trench from 87Hz-700Hz and a tough minimum of 2.85ohm/124Hz coupled with relatively large swings in impedance phase from –72°/66Hz (9.1ohm) to +51°/1.26kHz (7.5ohm).
totally agreeWhat I also want to add to my previous post:
There also comes room correction..
This could even influence the complete sound of you're system.
the whole idea is to mix old and new ( WiiM amp), but regarding to the remarks, i've doubtI think one has to also think about when using for instance bookshelf speakers you can add a sub.
Let's say for more depth,body in the music even if a speaker is more on the analytic ..,the depth , bass comes from the sub then( when needed).
I don't know if you have floor standing speakers if a sub is needed.
You can also adjust the sound with EQ,PEQ if you prefer this.
But it's something to think about ,also on price point ( costs of bookshelf speakers with sub or floor standing speakers).
If course it's also important to look out for second handed speakers..could make a big difference on price point.
I think you could go with the B&W,s or the KEFs..the whole idea is to mix old and new ( WiiM amp), but regarding to the remarks, i've doubt
About the time to break them inQuestion is also what do you want to spend on speakers?
If you buy them new on the internet i think you have the right to send them back within 2 weeks?
In this manner you could try them to see if you like the speakers?
I just want to buy second hands speakers (old ones) and an amp. Perhaps is it beter to go classical with an old marantz en a wiim pro instead of a wiim amp...i'm not sure anymoreQuestion is also what do you want to spend on speakers?
My experience is the sound from the amp is superb with my b&w speakers and the sub.I just want to buy second hands speakers (old ones) and an amp. Perhaps is it beter to go classical with an old marantz en a wiim pro instead of a wiim amp...i'm not sure anymore
If this really is your approach I would recommend indeed a classic. The Pro(Plus) for streaming an f.e. an iconic NAD 3020 as amplifier with some good 2nd hand speakers. A sexy combination in my eyes ;-)I just want to buy second hands speakers (old ones) and an amp. Perhaps is it beter to go classical with an old marantz en a wiim pro instead of a wiim amp...i'm not sure anymore
