Bit Perfect?
Silly-Ring
Nov 13, 2022
11
Hi there, can the Pro be configured to just output whatever is input? eg if i play 1 song on 16/44.1 and the out is automatically the same, the next song is 24/192 and the output automatically changes to match the input?
or if it cant now, is it likely to in the future?
Many thanks
Ahh i though it was specific, eg always upscaled to these settings, but sounds like you're saying, it will output whatever is sample on the input, but up to the settings in the app?
It will use original source resolution up to maximum set in Home app, and it will downsample if source resolution is higher.
