Crackling noise over wifi for Rega P3 turntable
jcrenner
Apr 28, 2024
I have the following set up, which works perfectly with my old turntable (Audio Technica LP60XBT). I recently upgraded the turntable to a Rega P3 with an Exact cartridge and suffer significant crackling over the left speaker (only left) on some tracks (which I presume is frequency-driven - it is over bass).
To try and narrow down the issue, I tried the following:
  • Switch the turntable back to the Audio Technica without changing anything else (playing the exact same track) ✅
  • Connect the Rega P3 and Fono preamp directly into Denon PMA-30 amp line input via a RCA cable ✅
  • Connect with WiiM Pro Plus and WiiM Pro directly via RCA line out / line in ✅
  • Connect to a second WiiM Pro into a completely separate amp (NAD D3070 v2) ❌
  • Swap the phono out into pre-amp ❌ (crackling then appears in the right speaker)
  • Connect the unused WiiM Pro Plus line out and WiiM Pro line in via a RCA cable to attempt to ground both units ❌
  • Ground the Rega Fono via the grounding port ❌
  • Change the line-in input resolution on the WiiM Pro Plus (all combinations) ❌
The only thing I can think of is the Rega Exact cartridge producing a weaker signal than the Audio Technica which could cause an issue with the WiiMs. Has anyone encountered anything similar or has a recommendation?
Your structured research is quite impressive, so far. In the end, I think, there is one single bullet point telling you the truth:
This is the 100% proof that the problem is with the turntable, indeed. I don't think that the crackling is a secondary effect on the WiiM. It's probably directly caused by the Exact.
I would expect this to have worked OK just by chance. If you repeat this setup, I bet the crackling will come back at one point.
Rega did have quality problems with the sourced magnets for their MM systems build in-house from time to time over the last years. I once had an Exact myself, which showed exactly this behaviour. The type of noise did not sound at all like it could have even been caused by a cartridge. But in my case I had just replaced the pickup, nothing else, and the crackling was there.
I got a working replacement unit and my dealer was already aware of this strange intermittent quality problem. For whatever reason it looks like it mostly affects the Exact, not the Elys. Maybe it's not just the coils being different but it might really use different magnets to create its higher output voltage.
So, my recommendation is to simply get the cartridge replaced.
I have to take back the claim of the Exact having higher output voltage. This is no longer the case compared to the newer Elys 2. The difference appears to be just the needle.
I stand by my guess that the cartridge is faulty.
Thank you so much @harkpabst - I genuinely believe it won't be the case (as one of the other tests I carried out was to plug in the P3 straight into the NAD D3070 v2 and it worked beautifully as well), but I fully take your point and will try again!
I assume you tried wiggling the cables, plugging in & out etc ? My old Rega P3 has notoriously poor cables & connectors (newer ones seem to have improved).
That said I'm feeding my Pro Plus with a P3+Exact via a Schiit Mani and I am seeing no such problem, it's all good
