Firmware disaster
pascalz
Apr 1, 2024
1
Latest firmwarecupgrade on wim pro produces a DAC disaster. Everything working fine before. Since upgrage the volume is not stable when a listen throug red/white exit.
Everything works fine throug the digital exit.
Not happy on thi firmware upgrage on a wiim pro plus.
Maybe someone can help me..
Check to see if the firmware update changed your audio settings. Was fixed volume on, or turned off by the update? Was the setting for the volume level also changed? Did you have equalizer settings, and if yes, were they changed by the update?
