Alpacamarc
- Joined
- Aug 2, 2023
- Messages
- 5
Hi all, as the subject states my Wiim Pro will not connect to our wifi network. It should flash white slowly after booting up but it only alternates green/white quickly. Holding the play button for 3 seconds does nothing, I've tried holding it for longer with no result.
The Wiim works via ethernet just fine, I've updated the firmware using this connection and also rebooted the device a few times via the Settings menu while connected to ethernet. When I unplug the ethernet cable however it goes back to the fast alternating green/white light but cannot be found in the app.
Any ideas? Thanks for your help
