If using the pro's line out then is it's analog output, so using the pro's dac.
If using either coax or optical out then it's digital output, so using receiver dac.
Wondering what you typed for autocorrect(?) to get "people's" in the title!
Since the AVR's DSP is digitally processed, the AVR's internal DAC is used regardless of whether the WiiM's built-in DAC is used. To avoid this, you must switch to a mode that does not use a DAC in the AVR (for example, direct mode).
example
WiiM > (RCA out) > AVR > (Direct mode) > Speaker out
