Very low output via rca
brianportugal
Sep 13, 2023
When I connected the wiim pro via toslink to the receiver it was very loud. Using rca out to the receiver so the sim pro plus dac is used the volume is almost half. I used to play on -35 now -25 is at a low level. Any suggestions?
Brian
Brian
In the Audio Settings screen, what's Line Out Level set to?
Brian
Although it is an amateur's idea.
What is the RCA output of the device you used before WiiM? Probably the output was larger than the WiiM.
