Klipsch sevens and wiim pro plus
Cagoper
Mar 7, 2024
I have pair of klipsch sevens speakers and wondering how can i get the best sound through wiim pro plus. Does it make any difference to connect through optic conneciton or rca? Thank you.
The Klipsch manual says
192KHZ / 24-BIT DECODING TO SUPPORT HIGH RESOLUTION AUDIO TRACKSThe Sevens powered monitors also feature 192kHz / 24-bit decoding for flawless reproduction of high-resolution audio tracks from your PC or streaming source.
Unfortunately that isn't necessarily applying to the Optical input. USB yes but unclear on Optical.
The best answer is "whichever you prefer the sound of".
