Loose Optical Port?
mason2spectral
Jan 3, 2024
Anyone else find the Optical Port on their amp is extremely loose? I've tried two different cables.
Also, finding the volume level over spdif is extremely low compared to Bluetooth with the same volume settings.
Usually, the input sensitivity for spfif and Bluetooth connection are different. I cannot find the detailed specification online.
Same here with the optical port…
Mine is scarily tight, on WiiM Pro. With the supplied cable. As I forced it in, when new, I hoped that the socket was anchored by more than some pcb solder pads. But it's not.
I just checked it now, for this post, and cannot pull the plug out!
