per-source volume?
distilledliquor
Sep 8, 2023
I'm using WiiM Pro Plus for an iPhone(airplay 2) and a PC(optical) but their loudness is too different to use with a concern.
I have to get the volume down about 50% if I play something with airplay 2.
I hope there's an update to make a volume preset as a per-source.
I'm running into the same issue using Tidal connect and Squeezelite. I would love to see the ability to have a volume level for different sources.
Amen!
My TV’s optical out “volume” is too damn low, compared to streaming services offered over Ethernet on the WiiM Pro.
@distilledliquor have you opened the ticket?
Assuming the processor is the same, this function, would find its way to both the pro and the pro plus.
Was about to log this myself. I need my optical input about 90% volume to watch a film at a reasonable volume, but Spotify connect only about 30-40% for same volume
Can’t find anything on my Samsung TV to adjust the optical out loudness
Did someone log a feature request for this already?
