Since the Squeezelite update, I have the system I wanted and it actually works! At first I had an issue where linked WiiMs had a delay, but an LMS restart fixed that. The skipping/jumping is also fixed, but it all that revolves around the new firmware, so to truly enjoy my system(s) I will replace my Mini and 2 AudioCast units for Pros.
The Pros are overkill for the garage, patio, and bathroom, but I will get them so all of the WiiMs integrate properly. My three existing Pros output digitally to a DSP, and then to nice amps and tower speakers.
Since I need to acquire 3 more Pros, I was wondering if there is any advantage to swapping the Pros on the good systems for a Pro Plus? Since I am not using the WiiM internal DAC, my understanding is they are otherwise the same. Any thoughts before I order? And I am waiting for one replacement to see if the WiiM Amp would be a better option for one area, but I am ALL IN on WiiM (Pros)!
Thanks!
Thanks!
