Pcryan5 Major Contributor Joined Nov 15, 2022 Messages 219 Location Vancouver BC Mar 6, 2024 #1 If I use Tidal Connect with wi-fi to speakers do I basically nullify the value of Tidal Hi Res and connect? Probably a dumb question so apologies.
M Mr Ee Major Contributor Joined Nov 11, 2022 Messages 1,992 Location Sydney, Oz Mar 6, 2024 #2 Pcryan5 said: If I use Tidal Connect with wi-fi to speakers do I basically nullify the value of Tidal Hi Res and connect? Probably a dumb question so apologies. Click to expand... Wifi to speakers? So your speakers have tidal connect built into them? Last edited: Mar 6, 2024
M Mr Ee Major Contributor Joined Nov 11, 2022 Messages 1,992 Location Sydney, Oz Mar 6, 2024 #3 Pcryan5 said: Not they do not - I read that WIIM does but I suspect i remove (so to speak) the functionality by using wi-fi to speakers. Click to expand... I think I need to uderstand what you mean by wifi to speakers... Not bluetooth, surely?
Pcryan5 Major Contributor Joined Nov 15, 2022 Messages 219 Location Vancouver BC Mar 6, 2024 #4 Mr Ee said: I think I need to uderstand what you mean by wifi to speakers... Not bluetooth, surely? Click to expand... No - instead of using an optical cable from WIIM to speakers - use airplay
M Mr Ee Major Contributor Joined Nov 11, 2022 Messages 1,992 Location Sydney, Oz Mar 6, 2024 #5 Pcryan5 said: No - instead of using an optical cable from WIIM to speakers - use airplay Click to expand... In which case you're really only benefiting from using the native tidal app
L LvdB Member Joined Aug 14, 2023 Messages 14 Mar 6, 2024 #6 AirPlay 1 and 2 don’t do High Res. Best you can get with AirPlay 1 is CD Quality.
