E En2099 New member Joined Dec 25, 2023 Messages 2 Dec 25, 2023 #1 Hello, found out my Wiim home music server in few folder has double tracks, unsure what happened, does any has same issue?
S simbun Major Contributor Joined Mar 4, 2023 Messages 832 Dec 25, 2023 #2 Try another control point such as BubbleUPnP or mconnect to see if the duplication persists. What server are you using? Upvote 0 Downvote
E En2099 New member Joined Dec 25, 2023 Messages 2 Dec 25, 2023 #3 simbun said: Try another control point such as BubbleUPnP or mconnect to see if the duplication persists. What server are you using? Click to expand... Hi, I’m using WD my cloud mirror, it was just happened today after the WiiM app was updated. Upvote 0 Downvote
S simbun Major Contributor Joined Mar 4, 2023 Messages 832 Dec 26, 2023 #4 I don't have a WD my cloud, but I'm not seeing any duplication in the Android app across a number of different servers. Have you tried browsing the problem folders in another control point? If you see the same behaviour then it's a server problem. Upvote 0 Downvote
