Volume Leveling for Chromecast
squebler
Jan 22, 2023
Is there a way to set volume leveling for Chromecast? I use YouTube Music, and some of the songs are really loud. Probably some are also too quiet. This is not a problem when I play YTM directly to the speaker. It only happens with Chromecast.
"Directly to the speaker" includes internal speaker of the android phone; Bluetooth connection directly to Bluetooth speaker; analog connection to headphones; and analog connection to BT speaker. So I believe YTM has an audio leveling feature that is not transmitted into the Chromecast stream. So the Chromecast stream is probably transmitting the raw file data, I assume.
Another option that should never be default. User menu choice.
