Wiim pro airplay equilizer
murra178
Nov 11, 2023
Does the wiim pro not support the equalizer with airplay output? I bought it so that I can take in some input from line in and then stream it via airplay with the equalizer settings. To modify the line input going out to the airplay speakers. Is this something that can be done, or do you have any recommendations of other products to do this?
I'm using a Wiim Pro to stream line-in audio to Airplay speakers with EQ adjustments. However, the EQ settings don't seem to affect the Airplay output. Is this a known limitation, or am I missing something? Any advice or alternative product recommendations would be appreciated.
I checked, but as you say, EQ cannot be used with AirPlay output.🤔
