WiiM Pro: how can I change the SSID?
KolfMAKER
Feb 1, 2023
I am using my WiiM Pro in combination with other Linkplay products.
With the Linkplay modules, I am used to change the SSID naming by using UART passthrough software.
Question
  1. Can I use the same software to change the default WiiM Pro SSID name into my own?
  2. What command string should I use to do this?
