It makes zero difference, I won't be able to hear it, but why would 192 lhz / 24 bit work for optical for me and only 16 bit 192 for coaxial digital? Is it a receiver limitation?
@HappyHighwayman
The only thing I wanted to say is, that it is not possible that the Yamaha can be the reason for your problem. The Yamaha sees no digital signal when he is feeded by analog RCA
