Firmware
axter
Oct 10, 2023
Hi, my mini have 4.6.530553 firmware version, but the wiim blog say that the latest is 4.6.530554.
Anyone have the same problem?
(I've been having connection problems and sudden stops for some time).
Thanks
Thanks
I think the blog is wrong. I also 553.
Thanks
My Pro firmware ends 554, so maybe just a typo. Also, different release firmware versions often have a much larger change in number, and the blog isn’t always bang up to date.
As usual, if you are having any problems where advice on the forum doesn’t help, you should submit a ticket to WiiM thru the feedback section in the WiiM Home app so your device logs can be inspected for evidence of your issue.
