The volume control for me changed the volume to lower by itself or could not stay at a specific setting . I hope with the firmware it is fixedIsn’t the limiter same effect as fixed volume off and adjust the slider like the limiter?
It’s part of the firmware updates as well as the new app that was release yesterday on iOS.Where is the volume limit?
Not found in Audio settings.
You need to set fixed volume on and limiter to 100%Can I just confirm that having the volume in the WiiM app fixed at 100%, and then controlling it from my amp, I’m still getting bit perfect signal please?
Thanks I’ll see if I can find the limiter. I had an update to the app todayYou need to set fixed volume on and limiter to 100%
My Android app is still not updated too.
It's only for iOS atm.No volume limiter that I can see. View attachment 2056
Ok thanks. I have an iPhone too. I’ll check later.It's only for iOS atm.
thank uThe final output volume level is the volume set on the device (or 100% if fixed), but no higher than the volume set in the limiter.
and that means now?Nah, it's more complex:
50% volume and 100% limiter is giving different result than 100% volume and 50% limiter...
