That means that the final volume is a multiplication of the volume set on the device and of the volume limiter.and that means now?
Just for my personal curiosity..you've wrote you use Roon, me too. So leaving the settings fixed or 100 and 100 and let the rest of the job with Roon is no good idea?and that means now?
sure it is, but was only a general questionJust for my personal curiosity..you've wrote you use Roon, me too. So leaving the settings fixed or 100 and 100 and let the rest of the job with Roon is no good idea?
Why you think is not a good idea?So output volume level as decimal value = volume on the device as decimal value (1 for fixed) x volume limiter as decimal value.
Decimal value is in the range <0..1>.
TBH I don't think it's a good idea.
I would rather expect the limiter to limit the maximum volume level possible, not to affect the volume all the time. Just my personal opinion.Why you think is not a good idea?
If you have fixed volume 100% and limiter to 90% doesn’t that mean that the output is 90% of the maximum ? By maximum I mean 2v rmsI would rather expect the limiter to limit the maximum volume level possible, not to affect the volume all the time. Just my personal opinion.
It does indeed, but consider also another case - volume at 50% and limiter at 75%. What result would you expect?If you have fixed volume 100% and limiter to 90% doesn’t that mean that the output is 90% of the maximum ?
Voltage level does not matter here, it's all about digital domain not analog one.By maximum I mean 2v rms
0.5*2v*0.75= 0.75 vrms . Yes it should allow only the correct one way setting that means volume should always be fixed to 100%It does indeed, but consider also another case - volume at 50% and limiter at 75%. What result would you expect?
Is this pushing digital out on higher voltage?Voltage level does not matter here, it's all about digital domain not analog one.
The problem is that 10% volume reduction has different impact than 10% limiter reduction. For 90% volume the signal is attenuated by 3.18 dB, but for 90% limiter it's attenuated by 6 dB. Total volume attenuated by 31.08 dB for my 50% and 75% case.0.5*2v*0.75= 0.75 vrms . Yes it should allow only the correct one way setting that means volume should always be fixed to 100%
Edit : 37.5 % volume
No, as maximum multiplier value is 1.Is this pushing digital out on higher voltage?
To add some headroom in the digital domain, to prevent from reaching unwanted volume levels. The WiiM will never exceed -6 dBFS when limiter is set to 90%, for example.I mean what’s the idea of this limiter if they want low out they can just turn off fixed volume and adjust it from there
Each 5% of the limiter has 3 dB attenuation.It would be good to have a headroom slider with -3db steps
Great then!Each 5% of the limiter has 3 dB attenuation.
