How to add Tidal album/playlist to a Preset?
HDP
Oct 3, 2023
While I have no problem adding Spotify albums to a preset, I just cannot figure it out on how to do this in Tidal. The 3 dots in the now playing just doesn’t give me saving to a preset option. As you can see from the screenshot, there is just a Sleep timer and EQ preset option. I have given Tidal access to my local network. I tried holding the preset button (in my case no 4, which is empty) on the remote control in but that didn’t work.
I have added Tidal playlists by navigating to the playlist in the Wiim Home app. Within the playlist, there is a 3-dot menu on the left hand side. Under that menu, one of the options is "add to preset“. I haven’t come across another way to do it.
Thank you for uncovering this @ihearurdog! Based on the UI, I assumed this was relegated for use only with Spotify and assumed I was left with 4 useless buttons on my remotes. Tested and works great!
