How do I add a radio station as a preset?
Doublej
Nov 24, 2023
117
USA
I can't figure it out, how is it done? I tried long pressing on the remote while the station is playing, nothing happens, I tried selecting the more button while the station is playing but all it brings up is the Sleep Timer and EQ.
I've also tried long pressing the 1 button on the remote, nothing.
Does it have anything to do with the fact that I told the WiiM to play the station using voice control?
Yeah, you can’t preset the stream resulting from a voice command. Best you could do is find the station under Tunein or VTuner and try presetting it from there.
