Keep disconnecting over wifi
JM1010
Sep 9, 2023
Just received my wiim pro. Playing spotify from phone over wifi but keeps disconnecting every few minutes even though wifi signal is strong. What should I do? Thanks
Try using 5ghz only. Strong signal doesn’t tell whole story as there maybe interfere on channel if you’re using 2.4ghz with your surrounding neighborhood.
I believe I have found the real cause of this super-annoying issue. There is a setting that puts the device in "standby mode", change it to "never". Once I did this connection is rock solid.
